I have an Estate green 2001 EB where can I get the Green and Tan touch up paint ? I need spray can and maybe a bottle. Where do I find the paint codes ? Thank You
paint codes can be found on the placard inside the driver door frame. A can of touch up in every color can be purchased from your local stealer. If you are in need of a larger amount, you may need to go a local body shop that you trust and have them mix it up for you as I don't believe the dealer sells that larger quantity.
