6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
loose steering
Old Sep 18, 2014 | 09:53 PM
99expyTN's Avatar
99expyTN
loose steering
The steering on my 08 F250 (41k miles) is loose. With the wheels straight, I can turn it to the one o'clock position and the eleven o'clock position before the wheels begin to turn. Sometimes I feel like I'm driving a bumper car where you have to crank on the steering wheel before it turns! I read some old posts that says the steering gear box could be loose and can be corrected by going through the steering gear meshload adjustment procedure. While the procedure does not seem overly complicated, it does require removal of the airbag, pittman arm, and measuring a peak preload torque and a peak on-center torque. Has anyone gone through this procedure? It looks impossible to get to the adjusting nuts on top of the steering gear box. Will this even fix my problem?
I'm not sure I want to tackle this job, but I dread going to the ford dealer. It won't be cheap and I'm afraid they will tell me I need a new front end.
Maybe I'll get lucky and you guys will tell me my steering is normal and I just have to get use to it.
Old Sep 19, 2014 | 11:03 AM
bubbasz1's Avatar
bubbasz1
I don't know about all that technical torque testing and what not, have someone move the wheel back and forth as you observe the pitman arm. If the slop is in the gearbox try adjusting it, if it gets better to your liking fine, if you need more go more, but I would only go 1/4 turn at a time. If you go for a test drive after adjusting it and it feels tight or won't return like it did, back off, if none of the above maybe it's time for a new box.
Old Sep 19, 2014 | 09:20 PM
deerslayer64d's Avatar
deerslayer64d
I had free play in my steering when I bought my truck and within a year I had to have the steering box replaced ( extended warranty covered this )
Old Sep 19, 2014 | 10:22 PM
Tenvol1968's Avatar
Tenvol1968
Mine do that was starring box, had to replace.
Old Sep 20, 2014 | 01:40 PM
RM2738's Avatar
RM2738
I had new Trac bar and ball joints put in after 40-50K and it was like a new truck. Steering was tight and borderline too sensitive and possible to oversteer very easily.
Old Sep 21, 2014 | 06:23 PM
99expyTN's Avatar
99expyTN
Well, maybe I don't need to go exactly by the procedure. Is it as simple as loosening the locknut and then rotating the meshload screw clockwise to tighten the steering? Do I need to separate the draglink from the pittman arm?
I'm still not sure how to get to the meshload screw. I may be able to get too it from the bottom, but this would be doing it blind.
Old Oct 15, 2014 | 06:46 PM
Tenvol1968's Avatar
Tenvol1968
Red Head, they are in Washington state, They had the best price when I replaced mine.
Old Oct 16, 2014 | 09:17 PM
parkland's Avatar
parkland
Did you determine for sure it's the steering box with the play in it?
I think changing the screw is only good if you only have a tiny bit of play.
Old Oct 17, 2014 | 05:44 AM
99expyTN's Avatar
99expyTN
Yes. It was definitely the steering gear. Here is a link to my install writeup. There is a video at the end that shows the play in the steering gear box.
Feb 23, 2018 01:12 PM
Scursion
Jan 10, 2013 07:57 AM
greenego
18
Oct 12, 2007 12:40 AM
Brats
May 29, 2007 06:10 PM
Trucker22
May 29, 2006 04:35 PM
