I Need Help!!
Old Oct 6, 2005 | 10:38 PM
beskitch's Avatar
beskitch
I Need Help!!
Does anyone know of a website that I can get diagrams of the 7.3 litre turbo diesel engine from? I have a bad oil leak and my mechanic ( who doesn't usually work on diesels ) has tore the engine down and found the leak, but does'nt know what the part is. From asking around, I think we have identified it as a high pressure oil sender but would like to be sure. The leak is from a two wire switch at the top front of the motor behind what I believe is the high pressure oil pump. We don't know if the switch is bad or if we just need to replace the o rings. Any help would be greatly appreciated.
Old Oct 6, 2005 | 11:56 PM
touchofgrey's Avatar
touchofgrey
Here you go: http://www.nav-international.com.br/...rStroke/hs.asp
Old Oct 7, 2005 | 05:52 AM
AustinS's Avatar
AustinS
Thanks touchofgrey, great link!
Austin
Old Oct 7, 2005 | 07:11 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
…Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 7, 2005 | 09:17 PM
cookie88's Avatar
cookie88
FTE Emeritus
The o-rings are and the two wire plug are part of the injection pressure regulator. Probably will take care off the problem, but if they don't....you know where to find us
