Need Help Starting 89 7.3
Old Oct 6, 2005 | 08:22 PM
crabhab's Avatar
crabhab
Here at work we have an old crab delivery truck 1989 7.3 automatic Diesel F-Superduty pickup with a reefer insert that has sat for two years. I know that the batteries are both dead. I tried to jump the truck using my F150 (I attached it to the correct battery per the owners manual) Nothing...just a couple of dash lights and clicking from the starter. I thought about swapping the battteries out of our 1995 powerstroke truck.
What would be the correct steps to revive this workhorse?
All your advice is greatly appreciated.
Old Oct 7, 2005 | 02:49 AM
texans's Avatar
texans
I would try batteries first. If that dosent do it then you might have a stuck starter. You said it would click but not try to turn the engine over correct? Try getting a hammar and tap on the starter. If it is sticking then it might free it up. if that works then you need to get a new starter. let me know if you need anymore help. GL
Scotty
Old Oct 7, 2005 | 01:18 PM
PLC7.3's Avatar
PLC7.3
I would check the oil and fuel for contamination. Hand turn the engine to ensure its not siezed or hydrolocked before attempting a start with two diesel rated batteries. Connect a direct fuel line from fresh fuel can to the lift pump until old fuel is checked or removed. Fuel filter replacement would be wise, with addition of a fuel additive ie Powerservice for diesels. Any bad fuel should go into the tanks from the system.........
Old Oct 7, 2005 | 02:32 PM
tjc transport's Avatar
tjc transport
i ain't rite
put in 2 fresh batterys. your 150 single battery with jumper cables will only provide enough power to do what you said, turn on some lights and a click or 2.
with fresh batterys and a check to see that all fluids are good, it should start up. my 88 7.3 sat for 3 years with a bad trans, and only took less than 1 min of cranking to fire up.
Old Oct 8, 2005 | 06:08 AM
bilder12's Avatar
bilder12
if your starter is good, dont overwork it by too long of cranking periods ... about 20 seconds at a time and let it cool down for about 2 minutes between.
loosen the injector lines til you get fuel to that point and then retighten them, it should start right up.
