66 brake master
Old Oct 6, 2005 | 04:30 PM
oleblu66's Avatar
oleblu66
66 brake master
I've got the old single master and would like to switch to a dual one but keep my drum brakes. Anybody know what I should be looking for, and also prop. valve if applicable.
Old Oct 7, 2005 | 06:11 AM
jowilker's Avatar
jowilker
oleblu66 Welcome to FTE The best truck show on the net.
Please use the search feature. That subject has been posted many times.
John
Old Oct 7, 2005 | 07:23 PM
oleblu66's Avatar
oleblu66
I would use the search feature, but I haven't the foggiest idea how to go about. Thanks anyway.
Old Oct 8, 2005 | 06:23 AM
jowilker's Avatar
jowilker
blue, Before you open a thread look in the upper right corner for Search this Forum
Most of us prefer to swap in the power disc brakes and power steering at the same time. That too has been discussed many times.
Hope when you have a few minutes you can go through the posts and find what you need.
happy hunting
John
Old Oct 8, 2005 | 07:37 AM
44dwarf's Avatar
44dwarf
I'll save you the time to keep manual drum brakes on all four corners use a 69 bronco master. Bolts up not changes. Broncos use the same bore on the wheel cyl so there no change in pedal effort.
44
Old Oct 8, 2005 | 04:44 PM
oleblu66's Avatar
oleblu66
thanks 44 dwarf. Any proportioning valve needed?
Old Oct 8, 2005 | 07:00 PM
44dwarf's Avatar
44dwarf
Nope Broncos had just a spool valve in them for Brake warning light not real a prop valve.
You will have to re plumb the truck for twin lines but you know that. 66 uses a pressure switch on the line so you'll need to junk yard hunt for a switch to go of the pedal.
44
Old Oct 9, 2005 | 09:45 AM
jd_sylvia's Avatar
jd_sylvia
oleblu66
I conerted to a twin master from a 70 Ford truck with the spool valve got all of the lines and spool from the junkyard new master but had to shorten the pushrod. other than that it all bolted right in. The factory lines look great even has a bracet that holds lines to steering box.
But for what it is worth I would start gathering parts for the disc upgrade. I completely rebuilt my drum brakes including master cylinder and when it was all done I probably could have gotten the disc brake conversion completed.
What ever you do have fun with it, it is all just a learning curve and some of us need to learn the hard way.
jd
