Just like instig8r63 suggested get a peice of sheet metal same gauge and mig it in ---OR--- Now would be a good time to think of your options, you can use that space for an electric antenna I put mine on the opposite side (view my gallery) only because I already filled in filler neck hole. But weigh options first. just take your time do it right, good luck
Just like instig8r63 suggested get a peice of sheet metal same gauge and mig it in ---OR--- Now would be a good time to think of your options, you can use that space for an power antenna I put mine on the opposite side (view my gallery) only because I already filled in filler neck hole. But weigh options first. just take your time do it right, good luck
Thanks for all your help, I have been thinking about putting the power antenna in for a little while, so that will be most likey what I will do. Thanks again.
