Bronco II Ford Bronco II
1986 bronco II
Old Oct 6, 2005 | 01:25 PM
annie1752's Avatar
annie1752
1986 bronco II
I have an 1986 ford bronco II and when I was driving home yesterday ... the rpms went down to 0 back up and then back to 0 and stalled.
We took off the pcv valve cleaned it and then the truck started. We waited for about an hour and tried it again and it started... but when we put it in gear to move it, it stalled again.
We tried starting it up again and it wouldn't start but here is the funny thing... We took the key out and it kept trying to start on its own until it drained down the battery. We have since recharged the battery but it is still trying to start on its own!
I don't know where to go from here any thoughts ? thanks for your help
Old Oct 6, 2005 | 07:11 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
…Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 6, 2005 | 07:51 PM
Ken00's Avatar
Ken00
Welcome to FTE!!
Pull the little wire off the starter solenoid and see if it's stops cranking. If it does I would check out the ignition switch, if it doesn't stop cranking then check out the starter solenoid.
For the no-start pull the codes, test the fuel pressure and check for spark.
Old Oct 6, 2005 | 09:00 PM
annie1752's Avatar
annie1752
thank you I will definitely try that in the am and let you know how I make out
Old Oct 17, 2005 | 12:10 PM
annie1752's Avatar
annie1752
we replaced the pvc valve and the starter solenoid and now it 's not starting on its own ... it started ran for about 10 minutes then stalled and now it won't turn over... so off to the garage we go... i will let you know what the problem was when /if i get it back thanks for the help
Old Oct 21, 2005 | 11:04 PM
annie1752's Avatar
annie1752
well it is now fixed it ended up being the computer... it got fried some how and it fried out the ignition switch and module as well... thanks for the help!
Old Oct 22, 2005 | 06:51 PM
Ken00's Avatar
Ken00
Glad to hear you got it running again!!!
breno1987
34
Mar 8, 2019 08:53 PM
cay5628
Jun 14, 2013 11:03 PM
Jnas860
Jul 2, 2012 02:19 PM
RANGER589
18
Jun 3, 2011 10:03 AM
Bob97F350
19
Apr 13, 2009 05:10 AM
