Daily Driver Primer
Old Oct 6, 2005 | 12:41 AM
shwagy357's Avatar
shwagy357
Daily Driver Primer
I have just finished replacing Door posts, striker posts, rockers, upper/lower qtr panels, floor pans, etc.. I am dieing to get the Bronco on the road as my daily driver. As of now, the only thing I have on all this bare metal is rattlercan self-etching primer (from Advance Auto). I was wondering what you guys think I should put on top of the primer before I expose it to the elements?
Old Oct 6, 2005 | 09:19 AM
Huntsman's Avatar
Huntsman
I would scuff things up and shoot the truck with some epoxy primer, just remember that a lot of primers aren’t UV tolerant so they will eventually break down if you try to go to long without top coating. Test the epoxy primer in an inconspicuous place to be sure it will not lift the rattle can stuff. You really never know when mixing products.
Old Apr 11, 2006 | 10:12 AM
markjw's Avatar
markjw
How soon would ya know?.Would it lift the rattle can primer right away? Or, should ya let it sit for a few days to see what the reaction might be?
Old Apr 11, 2006 | 10:35 AM
mudgepondexpress's Avatar
mudgepondexpress
I agree, DP40LF is what I would use. I think I would scuff off most of the rattle can primer before I applied the DP, it would just be easier in the long run.
Kenny
Old Apr 11, 2006 | 11:02 AM
fordraceboy's Avatar
fordraceboy
it will lift that stuff off immediately if it is going to do it at all... it wrinkles up and then you can just wipe it off without any effort. you'll know when ya see it...
Old Apr 11, 2006 | 11:50 AM
markjw's Avatar
markjw
Hey thanks for that fordraceboy......I'll certainly try a test panel first..Some "inconspicuous place"....like my wifes minivan..
Old Apr 11, 2006 | 01:24 PM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
lmao... I know I haven't helped... but reading that is priceless. I mean, that's what minivans are for, right..?
Ryan
Old Apr 11, 2006 | 01:33 PM
GWall's Avatar
GWall
Also keep in mind that most primers are NOT water proof and over time will allow moisture to get to the metal or body filler. Don't wait too long before you put some paint on it or you might have to redo some stuff you already did.
Old Apr 11, 2006 | 01:51 PM
mudgepondexpress
DP40LF and most epoxy primers are waterproof though. They will live years in the weather with no issues. The only thing I have ever seen happen is the color fades from them (no UV protection).
Kenny
avf100
Aug 14, 2013 05:25 PM
norvillebob
Feb 3, 2010 01:00 PM
TheSovereign53
Sep 16, 2006 09:40 PM
rmalottwtes30
Paint & Bodywork
Aug 15, 2006 03:57 PM
nixon_ca
Paint & Bodywork
Oct 27, 2004 12:50 AM
