primer selection
Old Oct 5, 2005 | 08:35 PM
HICKEY's Avatar
HICKEY
primer selection
what type of primer should i use after media blasting my cab and other parts on my 54
Old Oct 5, 2005 | 10:46 PM
Carlene's Avatar
Carlene
Admom
Hi Hickey, welcome to the Paint & Bodywork forum.
After sandblasting our '41, I used a self-etching primer and then an epoxy primer. From what I've learned in this forum, I'm probably over-killing on the primers, but the guy that told me the steps is an old-timer that has had a Paint & Bodyshop in the West Palm Beach area for over 50 years. I told him I wanted the best (not cheapest) way of protecting all the work I have into this project. He told me to go with PPG (I'm sure cause thats all he uses).
He said and I did, Sandblast, Metal Ready (or Ospho), Etching Primer, Epoxy Primer, filler if needed, High-Build Primer, Tweek with Icing (filler), then paint. I'm very pleased with the results.
I went with his steps because he's done this work for so long, specializes in classics and also raced with us on the local dirt track's.
From reading all the posts and being a part of this forum for so long, I know that the steps I've gone through are Over-Kill, but I'd rather be safe since I'm in it for the long term.
What I've learned here is that the current epoxy primers have the same etching qualities as the etching primers. I'd still suggest some sort of phospheric acid treatment (metal ready/Ospho/Pickeklex) before applying any type of primer. This stuff is watery and gets into places paint can't/won't.
BTW, I'm a firm believer that any filler/bondo goes OVER the epoxy primer.
Good luck with your project and I hope you put some progress photo's in your photo gallery.
avf100
Aug 14, 2013 05:25 PM
FordPickMeUp
Paint & Bodywork
Jun 27, 2008 01:56 PM
TheSovereign53
Sep 16, 2006 09:40 PM
rmalottwtes30
Paint & Bodywork
Aug 15, 2006 03:57 PM
JLb300
Paint & Bodywork
Jun 1, 2004 10:56 AM
