First off, I'm not a "diesel guy". The closest I've come to a diesel is a 3 cylinder NA Kubota tractor. But I have a question that's been bugging me for a while now, so I'll ask:
How does propane injection work in diesels? I'd think it would combust before TDC, and reduce power. But obviously it works good since a lot of people use it. Someone explain the theory of this stuff and how it doesn't destruct your engine.
I will try. This is what I learned when I did my homework before installing propane on my truck. This is just the gist of it. The propane has to have a spark to ignite, so it will not burn until the compression stroke is ignited. The Propane acts as a catalyst and bonds to the propane giving you a complete burn of the fuel in the cylinder. This is where you get your mileage increase and also a good shot of HP. somewhat, if you will, like nitrous on a gas motor. I know nitrous is not flammable, but propane is, it kind of like works the same. If you see a diesel blowing black smoke, that is just wasted unburnt fuel. The Propane helps burn all of that.
