4wd to 2wd conversion
Old Jun 15, 2002 | 10:26 AM
Greg50's Avatar
Greg50
So I've read some of the posts on how hard it is to convert from a 2wd set up to a 4wd, but is it equally hard to do the reverse? I know the cross members are different and the steering box is different, but can I just change out the axle for spindles and new linkage?
Old Jun 15, 2002 | 11:46 AM
mwc4275's Avatar
mwc4275
Why would you want to convert a 4wd to 2wd anyways?
Old Jun 15, 2002 | 01:03 PM
Greg50's Avatar
Greg50
Well I'm not fully decided, but what I did about 8 years ago was mount a 1950 F3 body on my 1979 4x4 frame. It just sounded like a good idea. I love the truck, but it never sees offroad duty. So I plan to make it more of a cruiser, not a low rider, but to make it more driveable on the street I want a transmission with an overdrive, and having the truck be 2wd gives me more options. So I'm just trying to weigh my options.
Old Jun 17, 2002 | 01:37 PM
sublimecharger68's Avatar
sublimecharger68
Old Jun 17, 2002 | 02:44 PM
Big Bad 1Ton's Avatar
Big Bad 1Ton
Have you thought about an IFS front suspension? It may be easier than swapping in the I-Beams
Old Jun 17, 2002 | 05:14 PM
Greg50's Avatar
Greg50
I'm trying to limit the amount of fabrication. Are there any IFS kits available? I'd love to hook up rack and pinion too, but I'm kind of looking for the easiest way out.
Old Jun 17, 2002 | 07:58 PM
mwc4275's Avatar
mwc4275
Why don't you just take your body off and stick it on a 2wd frame?
Old Jun 17, 2002 | 08:09 PM
Greg50's Avatar
Greg50
Mostly because we had to do some work to the front clip to get the front end pieces to fit. So I think refabing the body mounts would be more work. If I change frames I'd just go get a 1950 frame, but those generally come with more sheet metal and stuff I don't need. But those are just more options, I'm trying to keep this inexpensive too.
Old Jun 17, 2002 | 09:43 PM
leadmic's Avatar
leadmic
Is it a 3/4 or a half ton? And where are you located? I have all kinds of 3/4 ton 2wd stuff and would am looking for 4wd 3/4 ton stuff. Maybe we could work out a trade if your west cost.
Leadmic
Old Jun 18, 2002 | 05:42 AM
Greg50's Avatar
Greg50
That would have been nice, but mine is half ton stuff. The 3/4 ton uses leaf springs right? Because I'm pretty sure mine is a 1/2 ton, it has the coil springs. I'm in Detroit too.
