Toyota Steering Box?
Also what are the benifits over the factory one, and are there any cosmetic changes inside the cab? Changes refered to are column, wheel, etc. Thanks in advance to all replies.
The toyota box you are looking for is from the 1979-1984 4x4 trucks. Here is a couple of articles on the install;
http://www.bonusbuilt.com/toyota.html
http://www.classicperform.com/tech_a...0_Steering.htm
There are several guys around here that have installed it on the 53-56 trucks. Its a quick and easy install.
Good luck
Bobby
You can use the original column, you just need to saw it off the box (the shaft and box is one piece) shorten the housing, install a lower centering bushing (Mid Fifty) and grind 2 flats on the shaft to make it a doubleD shape to fit into the universal. The only small complication with using the stock column is you will lose the horn button function in the center of the steering wheel so you'll need to add a push button switch somewhere for the horm.
