Bronco II Ford Bronco II
o2 sensor
Old Oct 5, 2005 | 05:23 AM
Dragonfox13's Avatar
Dragonfox13
Question o2 sensor
Where is the o2 sensor hiding?
Dad says i need a new one, but i cant find it even in my Haynes manual =P
Any help is appreciated.
Old Oct 5, 2005 | 09:34 AM
mrshorty's Avatar
mrshorty
Can't say for certain on the 2.8L ('84-'85 BII's), but on the 2.9L ('86+), the O2 sensor is in the junction of the Y-pipe, just upstream of the catalytic converter.
Why does Dad say you need a new sensor? Preventive maintenance or are you troubleshooting a driveability issue?
Old Oct 5, 2005 | 03:02 PM
Dragonfox13
I told him its running really rich, and it sputters in idle, so he had me use FI cleaner, and that didnt help the problem, so thats the only other thing that could be it he said.
Old Oct 5, 2005 | 05:31 PM
mrshorty's Avatar
mrshorty
Bad O2 sensor is indeed one possible cause of it running rich like that, but certainly not the only other thing. O2 sensors are supposed to be replaced periodically as a matter of routine maintenance, so if it's been forever and a day since the O2 sensor was last replaced, it wouldn't hurt to replace it as maintenance. But, as a matter of troubleshooting a driveability problem, I would start by 1) pulling codes from the computer, 2) Check for fuel in vacuum line to fuel pressure regulator (fuel in line=bad FPR), and 3) Check fuel pressure. For instruction on (1), see "pulling EEC-IV codes" in Ken00's tech info post and for (2) and (3) see "checking fuel pressure" in Ken00's tech info post at the top of this forum.
Old Oct 6, 2005 | 12:31 AM
Dragonfox13
thanks, ill do that.
