Sponsored by: Real Truck
F250 check engine
Old Oct 4, 2005 | 08:06 PM
radami's Avatar
radami
F250 check engine
Has anyone ever had an F250 have the check engine lights, and other lights on the dash blink, then stop, sometimes the tow haul light will blink and as this happens it turns off and all power is gone, as if the battery was disconnected. Well I disconnected the battery and it fired right up like nothing was wrong.
Old Oct 4, 2005 | 08:48 PM
Edsf250's Avatar
Edsf250
4wd High
I have a 250 also and the check engine light comes on... every so often ...oxygen sensor was bad....
Old Oct 4, 2005 | 11:12 PM
radami's Avatar
radami
did someone diagnose this, and if so, what was the code
Old Oct 5, 2005 | 04:10 AM
slc10844's Avatar
slc10844
If there were codes, when you disconnected the battery they were erased. If it happens again you might want to have a computer scan done to check for codes.
Old Oct 5, 2005 | 06:46 AM
Edsf250's Avatar
Edsf250
4wd High
I used the ngs ..
Old Oct 5, 2005 | 06:53 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
…Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
