Mods for a 4.9
You wanna have the head checked for cracks first, before you do anything, especially an efi head.
Then port the head.
Once you have it ported, take it back to the machine shop.
Head work, cam, boost compression, intake, exhaust, ignition upgrade ... do them all at once and choose each portion of that to work together with all the others. In other words, don't switch to a radical race cam if you aren't also going to boost the compression a whole bunch, switch to an intake that can flow a lot of air, port the heck out of the head, upgrade the valve train, switch to full length headers, etc..
What your not factoring in, if you go with a smaller aftermarket camshaft aka RV, its function is to build cranking cylinder pressure with low compression engines build low rpm power, good for the street. Where a higher grind camshaft is designed to bleed it off somewhat, due to higher static compression ratios.
The stock 300 head is restrictive. Luckily you can mill the head a little more than usual, for increased compression, all part of the machining process.
One very good example of why a large camshaft is not required, look at Col Flashmans build.
I agree a combination of modifications have the ability to make more power in the end but bigger isn't always better.
