Oil Pressure Sending Unit Threads
Old Oct 11, 2005 | 11:54 PM
rabbithutch's Avatar
rabbithutch
Anyone know the size and pitch of the threads for the oil pressure sending unit? I want to rig up to have both the stock oil pressure switch AND an after market op gauge running simultaneously. The gauge instructions show that you can drop in an adaptor and a "T" fitting and put the factory op sending unit on one of the fittings and their gauge on the other. If I do this, it'll be on the ground as I don't have access to a lift. At my age (63), I don't want to be crawling in and out learning any more than I have to.
While I'm at it, what do you think would be a 'reasonable' price to pay to have someone install a triple after market gauge set (op, ammeter, water temp)? Where would you install it on a '90 F150? I can't seem to find any place reasonable under the dash so thought I'd do it on the floor behind the stick. Any other ideas?
TIA
rh
Old Oct 15, 2005 | 12:28 AM
63redtudor's Avatar
63redtudor
I belive that its 1/8" pipe thread.
Edwin
Old Oct 17, 2005 | 08:39 PM
Kista20's Avatar
Kista20
actually it's a 1/4-18 npt (national pipe taper).
Old Oct 17, 2005 | 09:29 PM
DT 466Man's Avatar
DT 466Man
yup yup 1/4 inch got it from Lowes worked like a charm, but gotta get a small nipple to go into the block then put the t on the end.
i think there's a pic in my gallery
DT
Old Oct 17, 2005 | 11:53 PM
Schmids4.9l's Avatar
Schmids4.9l
(http://) store.summitracing.com/default.asp?target=egnsearch.asp&N=300137+42949083 31&autoview=sku
copy & paste that to your browser, since the links don't seem to work.
or, google search 'gauge pods 90 ford f150" and summit will be the first link.
around 20 bucks for these gauge pods. they mount on the windsheild A-pillar. look pretty cool. My buddies with diesels get them for their boost gauges and what-not.
Old Oct 19, 2005 | 11:12 PM
63redtudor's Avatar
63redtudor
Oops, I stand (or sit I suppose) corrected.
Edwin
