Odd Clicking Sound
Old Oct 4, 2005 | 01:16 PM
Wes64052's Avatar
Wes64052
Odd Clicking Sound
Hello:
I have a 2003 F250 CC SB. I just got it back yesterday from the detail shop and as soon as i started it, it started making this clicking noise from under the dash. It is on the driver side and as best as I can tell it is just behind where the storage knook is in the dash. I have noticed that it is very inconsistent and sometimes does it real bad and sometimes only for a second, I have also noticed that if it is doing it and I apply the brakes it stops and as soon as I let off may begin again immediately or wait 10 or 15 seconds and start again. It sounds like little plastic gears stripping. Any hints.
Thanks
Wes
Old Mar 30, 2011 | 11:17 PM
firepmedic51's Avatar
firepmedic51
Did you get this problem resolved? I currently have a 02 F250 XL doing the same thing. Radio will light but does not work, no power at fuse panel. Fuel gauge has a mind of its own. Thought it might be sending unit, however, it seems as if it is related to that clicking.
Old Apr 3, 2011 | 09:22 PM
HomerWinzlow's Avatar
HomerWinzlow
The clicking noise the OP mentioned back in 2005 was likely a bad ground through the multifunction switch (turn signal/wiper/4way flasher switch) assembly. This will have nothing to do with your radio or fuel sender however.
Old Apr 3, 2011 | 10:34 PM
firepmedic51
HomerWinzlow, thanks for the information and post.
Wizness
6.7L Power Stroke Diesel
Aug 31, 2015 03:24 PM
wwarren03
1997 - 2003 F150
Feb 12, 2014 10:15 AM
SideWinder4.9l
49
Jan 29, 2014 06:43 AM
wd13
Feb 25, 2010 05:00 PM
Wes64052
Garage & Workshop
May 3, 2004 05:25 AM
