They should be held in with 3 or 4 screws. They are incredibly easy to replace as well. Remove the door panel, and then unscrew. The hard part is knowing what color wire is the + and which is the -. The way I always did it was to hook it up one way and see which way the cone travels. It should move forward, not backward.
