transmission again
Old Oct 3, 2005 | 09:37 PM
lucky no. 7's Avatar
lucky no. 7
transmission again
well just figured there is alot of transmission questions goin around so i thought i'd add to them, i drive a 95 f-150 everyday at work its got a 302 with a E4OD and it got 94000 original miles, my question is that when i am goin down the road i overdrive, it seems kinda like it just kicks into neutral for a second, then it'll kick back in, i have been thinkin about it, and have come to a conclusion that it may be a vaccuum leak to the modulator or its an internal leak, any suggestions and help on this would be apppreciated
Old Oct 4, 2005 | 03:43 AM
serving_time's Avatar
serving_time
there is no vacume module on that tranny. it is all controlled electronically by the computer.
Old Oct 4, 2005 | 06:15 AM
95 F150's Avatar
95 F150
Has the transmission fluid and filter ever been changed, the filter could be dirty not allowing fluid to pass through it causing the trans to slip. This happened on a Mustang we used to have and the fluid and filter change did the trick.
Old Oct 4, 2005 | 10:12 AM
quicklook2's Avatar
quicklook2
you also need to drain convertor.
these trans. have a problem called 'shudder' it feels like driving over a washboard.
Old Oct 4, 2005 | 10:52 AM
oldstylefseries's Avatar
oldstylefseries
Greetings,
When you feel this, are you coming off the gas (coasting) then stepping on the gas again? If so, what you are feeling is the torque converter locking/unlocking. When you tap the brake pedal or (in some cases, depends on vehicle) come off the gas, the torque converter unlocks. When you step on the gas again, you will feel the torque converter slip (unlocked) then rpms go down smoothly, and the converter is locked.
This is just something to look for, and you may be chasing a problem that doesn't really exist.
Hope this helps,
Tim in New Baltimoe
95 F150, sc. sb. 5.8 e4od.
Old Oct 4, 2005 | 11:39 AM
McLeod's Avatar
McLeod
This is a common question.
Do a forum search for slipping transmission and you will read all day.
Take a look at this thread for starters:
https://www.ford-trucks.com/forums/s...osition+sensor
LittleRedRanger4.0
Dec 14, 2012 09:55 AM
Splatts
18
Dec 9, 2011 07:23 PM
79FordBlake
Jun 10, 2010 05:13 PM
Truxx1956
50
Jun 24, 2008 12:13 AM
GasMonkey
Mar 25, 2004 09:09 AM
