Welding on a front end
Old Jun 23, 2002 | 03:23 AM
karljay's Avatar
karljay
I've seen other trucks that have supports welded to the axle housing and was wondering if some special type of welding was used for this. I know that when you weld a block it takes a special process for it to come out right, but I don't know if this applies to a D44 front end.
Is it cast iron or can it be welded with a oxy/ace setup? Can you weld to the center section or just the axle tubes or both?
Old Jun 24, 2002 | 09:39 PM
Scot's Avatar
Scot
The center section is cast iron and would have to be arc welded with a nickle rod. Even then it would not be very strong. The tubes are steel and I have welded spring perches and the like with an arc welder. I can gas weld as good as anyone but would not even attempt to weld an axle tube with it.
Old Jun 24, 2002 | 09:56 PM
Mike W's Avatar
Mike W
Hi Scot, Have you ever had any problems with warping after welding on the tubes?
Old Jun 25, 2002 | 08:22 AM
Scot's Avatar
Scot
Not that I could tell. I usually weld it with something like 1/8" 6011 @125 amps DC.
Old Jun 25, 2002 | 09:52 AM
FordBlue's Avatar
FordBlue
kevin316
Aug 20, 2012 02:13 PM
averagef250
Aug 15, 2009 09:58 PM
god.boots
Offroad & 4x4
Oct 11, 2006 07:45 AM
generalee31184
Apr 10, 2006 08:43 PM
sancochojoe
Garage & Workshop
37
Apr 9, 2004 10:40 AM
