A/C help
Old Nov 22, 2005 | 08:17 AM
fatfenders56's Avatar
fatfenders56
Originally Posted by Christopher2
Could someone install the parts of the A/C that go in the vehicle someplace besides the dash? Maybe under the seat?
The touchy thing about this is the length of the lines versus the total volume of the system, maybe someone more knowledeable could address this
Old Dec 10, 2005 | 04:53 PM
tacson's Avatar
tacson
I find this site while searching the web the other day. Might help someone.
http://www.nostalgicairparts.com/index.php
Old Dec 11, 2005 | 11:39 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Chris, I think the real issue in the case of a pickup is that people generally want the cold air blowing on their face and upper body, especially during cooldown. Having it blow on your ankles may cool the cab down just as well, but if the sun is still shining on your arms and chest, it won't feel like it. I suppose you could snake some tubes up behind the seat to blow forward, but that would be awkward.
As much room as is in the fenderwells, something like the Magic Aire system would seem the logical way to go -- put it in there and feed conditioned (heated or cooled) air into the cab thru that port. You'd need to suck fresh air from the front.
Old Dec 12, 2005 | 07:44 AM
49willard's Avatar
49willard
I just mounted an AC evaporator under the dash of my 49. I bought it years ago for a different project. It was air only as purchased. I added some enclosure fabbed out of black ABS sheet stock to house a heater coil, added it to the existing AC enclosure and fit the whole setup under the dash. I maintain an operating cowl vent, electric wiper but will lose about 1/3 of the glovebox. Note that this would not work with a radio in the stock position. I agree with ALBUQ F-1, cold air sinks. You want the AC to direct toward your upper body.
