my 429 help
Old Oct 2, 2005 | 06:42 PM
just1me's Avatar
just1me
my 429 help
I have a 1972 429 ok here is the thing i redone it still had the 8:5:1 cr,but i took off the d2ve heads and put on fresh d3ve heads same cc ,and i eliminated the a/c ,smog, egr, cam is stock, so is the intake but im running a holley 3310-750cfm carb, 160 thermostat, and dual 2.5 exhaust how much power should i be making and also where is the best place to sit the timing like 10,12,14 degress
Old Oct 7, 2005 | 07:43 AM
smoke n tires's Avatar
smoke n tires
problably 12 degrees and maybe 250 hp and 350 ftlbs........you need an intake, cam and good headers. also a 180 t stat. then you might be around 350hp and 450 ftlbs.
Old Oct 7, 2005 | 11:46 AM
just1me's Avatar
just1me
curious
Thanks, out of curiosity what is the max lift and duration you can use on stock pistons without any p/v issues and how much can the stock springs handle? Im asking cause of my 72 429, but my uncle has a 1969 429 he is hopping up, he already has a offy intake, and a holley 750cfm carb, headers for his.
dirtyoffroad
Aug 26, 2025 01:01 AM
CharlieLed
13
May 25, 2024 10:56 PM
taylorbickett5
Ford Truck Parts for Sale
May 13, 2015 05:04 PM
77 2wd
Dec 4, 2012 09:09 PM
77 2wd
32
Aug 5, 2012 10:23 PM
