16" wheels
Old Oct 2, 2005 | 12:48 PM
jjz 109's Avatar
jjz 109
16" wheels
I am looking for some info on 16” wheels. I need 8 lug stock type wheels that will fit a 72 Dana 44 front end with drum breaks. The set I have will fit the Dana 60 rear end but will not go on the front end, they will not seat against the brake drum. Did Ford make a 16” wheel to fit this application? Any help would be appreciated.
Old Oct 2, 2005 | 02:16 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Welcome to the forum, you will get more responses if you scroll down the left column to the brakes, wheels, suspension, ect. section, maybe more help.
.....=o&o>.....
Old Oct 2, 2005 | 09:58 PM
Fomoko1's Avatar
Fomoko1
What is stopping the wheel from contacting the brake drum, is the center hole of the wheel too small?
Old Oct 3, 2005 | 08:04 AM
jowilker's Avatar
jowilker
You must have a non Ford wheel, a wheel that will fit the rear will fit the front. IMHO
John
Old Oct 3, 2005 | 11:33 AM
jjz 109's Avatar
jjz 109
16" 8 lug
Looks like the wheels I have are some kind of Chevy wheel. I think Ford welded their wheels together where-as Chevy riveted there’s. The ones I have are riveted together. I thought that the center hole was smaller on Chevy wheels, but not on these. Doe’s any one know of a chart that shows info on what fits what regarding Ford 8 lug steel wheels.
Will latemodel disk brake wheels work with the early drum brake set up? 16x7 8 lug is what I need.
Old Oct 3, 2005 | 01:53 PM
bertha66's Avatar
bertha66
I have a 68 1 ton that I've put 99 Ford wheels on, but I have to finish a adapter for the center hud to center the wheel on the old axle.
Old Oct 4, 2005 | 07:24 AM
jowilker's Avatar
jowilker
jjz, Some of the Chevy wheels will fit. They all were using Dana axles back when thus the reason for the swap.
Late model wheels are centered by the lug nuts not the wheel opening, so the problem wont go away.
John
Johnny Be Cool
Jan 27, 2015 07:40 PM
JDH6621
Jan 2, 2006 10:21 PM
showtimes ford
Mar 9, 2004 11:05 PM
Fiddleback
Dec 18, 2003 09:18 PM
Matthias
Dec 9, 2003 10:32 PM
