changing heater core 81'f100
Old Oct 2, 2005 | 11:57 AM
F-150Guy's Avatar
F-150Guy
Its starting to get cold here, and should be changing my leaky heater core before the snow hits the ground. What do i have to do in order to change it? any help is appreciated, thanks.
Old Oct 2, 2005 | 12:17 PM
Lee Lichterman's Avatar
Lee Lichterman
It depends on if you have A/C or not.
If you have A/C, you change it from the inside of the cab. It is easiest if you take the glove box out, not the whole dash, just the inside glove box liner part. Whole thng takes about 30 minutes and is easy. Pull the glove box liner out with the 4 or so screws. Unplug the little electric doo-dad on the heater box, pull the cover of the heater box off via the 10 or so 5/16 screws. Hard part is pulling the 20 year old hoses off the heater core from the underhood side. CAREFULLY take out the rubber gasket/filler pieces that hold it in place from the underdash side and don't foget to put them back in like I did so you have to do it again. -g-
Once the hoses are disconnected, the whole thing just lifts out from inside the cab and you slide in the new one.
You will need a friend to help put it in. Nothing really holds the heater in place except the hoses and that rubber gasket thing so they will need to put pressure to hold it in place while you push the heater hoses to the core so you get them on there all the way.
If you don't have A/C, then the whole thing is done from under the hood and it comes out under the hood as well.
While you are in there, you should be prepared to get a shopvac in there and clean it all out. You would be amazed at how many leaves and pine needles etc fall in there.
Good Luck,
Lee
Old Oct 2, 2005 | 06:39 PM
F-150Guy's Avatar
F-150Guy
thanks alot, i'll get started tommorow
Old Oct 3, 2005 | 07:43 AM
Holmesuser01's Avatar
Holmesuser01
Believe it or not, the A/C heater core is easier to do than the regular heater. Done them both. If it is A/C, take the extra time to pull the heater motor (under hood) and clean all the crud out from that side of the evaporator, then spray a load of Lysol on that side of the coil. My truck, after the core changes, started really stinking when first turning on the A/C. I washed the evap with lysol, and back-sprayed the evap with water from the hose while I had the heater core back out. Now, the truck no longer smells like a dead animal when A/C comes on.
At any rate, clean everything you can while you have it apart. It will make a difference!
Hi Lee!
