Propane Grill Question
Old Oct 2, 2005 | 12:14 AM
weadjust's Avatar
weadjust
Fired up the propane grill tonight to cook some steaks. Preheating the grill and it ran out of gas. No problem I have a back up tank.
Hooked up new a tank and the grill wouldn't work properly. The propane regulator would freeze up (ice on the outside of the regulator) causing the gas flow to stop.
What would cause this??
Old Oct 2, 2005 | 12:51 AM
jake00's Avatar
jake00
I do know that propane can freeze, was it cold out?
Old Oct 2, 2005 | 03:19 AM
BoomerD's Avatar
BoomerD
Almost sounds like the bottle was overfilled. Sending liquid propane through the regulator can indeed freeze it up, which is a good thing, because the grill is NOT made for liquid propane, only propane gas. I've had a couple ruined that way over the years.
Old Oct 2, 2005 | 07:30 AM
76supercab2's Avatar
76supercab2
What happens when liquid propane gets in the grill?
Old Oct 2, 2005 | 09:20 AM
Icefan71's Avatar
Icefan71
Same thing happens at work if we open a CO2 bottle too much. The line gets snow around it. Maybe it is flowing too much propane?
Old Oct 2, 2005 | 09:29 AM
lenny1carl's Avatar
lenny1carl
could be a leak in the fitting. mix up some dish liquid in warm water and poor on all the connections. turn the lalve 1/3 open and chk for bubbles<---- the leak. wipe off the mix right away after. it stains
Old Oct 11, 2005 | 07:03 PM
propaneguy's Avatar
propaneguy
Sounds like your getting liquid. This isnt too good. Problem is liquid pressure is dependant on temperature, so once the liquid is past the regulator it will begin to increase in pressure. At 70* propane pressure is around 118 psi, your bbq only needs 1/2 lb of pressure. Another problem is that one part liquid = 270 parts vapor. Either way its not real safe to use that way. I would take it back and exchange it for another.
John
t_dickie
Sep 3, 2006 02:21 AM
rywegh
Jul 9, 2006 07:11 PM
76supercab2
May 28, 2004 09:57 PM
13hondacr250
38
Sep 13, 2003 11:37 PM
