Leaf Spring Slipped
Old Oct 1, 2005 | 10:24 AM
Phrekkle's Avatar
Phrekkle
Leaf Spring Slipped
05 FX4
Okay....Long story short.....I have the slip clunk, have taken it to the dealer 5 times, and Wednesday will be thier Final Attempt at repair.....however, the last fix (a week ago) they put a 1 degree shim in the rear.......yesterday it started shaking pretty bad at 45mph, even scared my kid.......
I took it home and looked at the back end, just to see if my pretty much untrained eye could see anything.......I did notice that the passenger side bottom leaf spring (at least I think thats what its called....the slabs of metal stacked up beside the rear wheels) anyhow, the passenger side bottom one is off about 1/2 to 1 inch....the back has slipped closer to the tire, and the other end closer to the center of the truck.
I called the dealer, to ask whether I should be driving it, at least until Wednesday, and he said it would be a good idea to park it until then.
What are your thoughts? How bad is this? Does it mean they put it back together wrong?
Help
Old Oct 1, 2005 | 03:29 PM
66ratkiller's Avatar
66ratkiller
i have an 04 scab fx4 pass. side is same way shakes like crazy all the time i to am curious about this.
Old Oct 1, 2005 | 08:03 PM
les017's Avatar
les017
my driver side rear leaf did the same thing AFTER I installed my 2" rear shackle drop with 2 degree shims. I KNOW I had the alignment holes lined up with the pins but the leaf slipped anyway.
What I found was that, even though I torqued all of the u-bolts the same I must have tightened the front bolts sooner than the rears. This caused the rear alignment to pull down out of the alignment hole in the shim.
Lossened and retorqued EVENLY and have not had the problem since.
Remember, setting these shims between the spring pack and the axle plate efectively shortens the spring alingment pins. But, I only noticed my spring pack to have slipped upon visual inspection. This never caused me any vibration at all
Old Oct 1, 2005 | 11:22 PM
kize's Avatar
kize
My thoughts? It not only is a safety issue but it would cause a mis-alignment in the rear end. Could it cause a vibration issue? It would be something I would want to rule out.
Old Oct 4, 2005 | 08:00 AM
jhromy's Avatar
jhromy
yes if the rear is out of alignment the truck will vibrate.
robert_l_ross
Sep 1, 2023 03:17 PM
SuperDuty93
30
Apr 30, 2022 09:17 AM
USRanger379
New Member Introductions
Mar 24, 2017 02:25 PM
doug42190
Jan 29, 2016 10:43 PM
Jet Lizard
Aug 13, 2004 10:25 AM
