BLACK smoke??
Old Jun 26, 2002 | 10:33 AM
1ole4d's Avatar
1ole4d
BLACK smoke??
Ok...I know blue smoke is caused by burning oil but what causes black smoke? I rebuilt the motor in Oct. and had the heads redone at the machine shop in town. I had to put another new carb on it about a month or so ago and ever since then the truck has a stumble in it when you pat the gas. I noticed yesterday when I pat the gas a few times back to back not only does it stumble but some black smoke comes out of the tail pipes. I don't run cats on it and I have a dual Flowmaster muffler set up which is only a year old. Any ideas? Seems like I remember from class that if black smoke comes out it is running either lean or rich....I can't remember which one it is though. What could be causing this stumble and black smoke???
1978 F-150 flareside. Primitive by todays standards but she was a jaw dropper back then. :-staun
Old Jun 26, 2002 | 10:37 AM
TheWiz427's Avatar
TheWiz427
BLACK smoke??
It's running rich adjust the carb to lean it out a little.
Wiz
An Equal Opportunity Truck Lover!
http://www.clubfte.com/users/thewiz427/index.html
Old Jun 26, 2002 | 10:57 AM
1ole4d's Avatar
1ole4d
BLACK smoke??
Thanks Wiz...I had a feeling that's what it was.
Old Jun 26, 2002 | 11:07 AM
Vampiro's Avatar
Vampiro
BLACK smoke??
black smoke is gas, blue is oil and white is antifreeze. like the wiz said your engien is running too rich or you might need to rebiuld your carb
Old Jun 26, 2002 | 02:37 PM
dfisher1's Avatar
dfisher1
BLACK smoke??
All,
He said it's a new carb. Rejet!
KingFisher
P.S. Do it now before you wash out the rings and have to rebuild the bottom end.
Old Jun 26, 2002 | 03:45 PM
76supercab's Avatar
76supercab
BLACK smoke??
He also said stumble on acceleration. I'm thinking a problem with the accelerator pump-- too large a shot.
Old Jun 26, 2002 | 11:09 PM
1ole4d's Avatar
1ole4d
BLACK smoke??
[updated:LAST EDITED ON 27-Jun-02 AT 00:13 AM (EST)]>All,
>KingFisher
I'm sorry...I don't quite follow that. What do you mean by wash the rings out
Ahhh..wait...now that I think about it I think I get it. You mean all the excess gas washing the oil off the piston rings and eventually getting onto the mains correct?
Old Jun 29, 2002 | 11:41 AM
jeffreysw's Avatar
jeffreysw
BLACK smoke??
Raw gas is a solvent, not a lubricant. If you're running really rich, the unburned gas dilutes the oil being applied to the piston rings, which is really bad. Too rich is either too much gas or not enough air. Patting the throttle activates the accelerator pump, which squirts gas directly into the throat. If the carb is new, it still needs to be set up for your truck. Most carbs have accelerator pump plus two or more circuits. Pilot jets meter during part throttle and main jets meter during full throttle. The pilot jet should have an air screw that will give some adjustment, but if the jetting is extremely off, it may have to be replaced with a different size. Main jets are usually just replaced. The only way to really dial the set up in is reading the plugs and driving the truck to note changes.
Old Jun 29, 2002 | 12:40 PM
tetraruby's Avatar
tetraruby
BLACK smoke??
