Carburetor Question, please help!
Old Oct 1, 2005 | 01:11 AM
Third Coast's Avatar
Third Coast
I just put a kit in my one barrel carb on my 1950 flat head six. It started up fine and idled but I have a fuel leak when I pump the throttle. I took the top off of the carb with it still on the truck to pinpoint the problem. When the pump is actuated fuel comes up to the split line, past the "Pump Discharge Needle" and the pressure is enough for the fuel to shoot out of the split line of the main body. If you have a manual, the "pump discharge needle" can be seen if Fig 59 on page 110. I also noticed that when I took the carb apart the first time, I never saw the "pump check ball" and the "pump check ball retainer", There was a retainer holding the "pump discharge needle" in place but I never found a ball and from the picture in the manual I can't tell where the ball is supposed to be installed. Now I'll get to my questions.
1. Is the leak I'm experiencing at the split line a simple split line leak that needs more attention or am I missing something else? With the top half off of the carb I can cover the hole over the pump discharge needle with my finger and when I move the pump it shoots a nice streem into the throat of the carb.
2. Could the check ball cause this problem or is it unrelated?
3. Does anyone have a better picture of a this carb, I can't tell where the ball and retainer are supposed to be from the manual. The number on the carb is a Holly 897.
My grandfather had a guy rebuild this carb a few years back and it never was right, I'm wondering if it has been missing a piece or two for quite a while.
Any help you can give would be appreciated.
Old Oct 1, 2005 | 09:23 AM
Christopher2's Avatar
Christopher2
Veteran: Navy
Is it an 897 or an 847? The reason I am asking is I have an actual manual for the Holley Model 847 Carburetor Downdraft published Dec 12, 1950.
Old Oct 1, 2005 | 09:33 AM
Christopher2
Veteran: Navy
If it is the 847 go here.
http://www.thecarburetorshop.com/Carbshop_lit.htm#Carb_Holley
Then look for this manual
847 – 1950 Holley Service Manual covering Carburetor Model 847 carburetors as used on Ford Motor Company 6 cylinder passenger cars, trucks, and buses. 8 ½ x 11 inches by 27 pages. EXCELLENT service manual for these carburetors. Exploded diagrams; cutaway diagrams; actual pictures; step by step disassembly, reassembly, and adjustment procedures. Good used condition. Stock number Lit-0122. Price $20.00.
It has the pictures you are looking for and much more, it is worth the money.
I am also going to try and scan it into a PDF no promises it loks like a long process for 26 pages.
Old Oct 1, 2005 | 10:26 AM
53wa2fl's Avatar
53wa2fl
And just to try to put in my $.02, the check ball could very well cause the problems your describing.
Old Oct 1, 2005 | 09:53 PM
Third Coast
The number on the carb is 897. When I bought the rebuild kit the kit number was the same for a 847 and 897, I'm not sure what the difference is or when the carb may have been changed out. This truck entered the family in 1977 and this carb was on it when it was purchased.
Old Oct 1, 2005 | 10:07 PM
Christopher2
Veteran: Navy
I sent you a private message I have the 847 manual in PDF if you are interested.
Old Oct 1, 2005 | 10:37 PM
Third Coast
Christopher 2, I also sent you a private message.
raven3
17
Jan 6, 2024 11:55 PM
cwtaft
Feb 2, 2013 11:51 AM
johnboy427
May 24, 2009 12:25 AM
HawgDawg
Mar 13, 2005 11:51 PM
