any ideas
i left to drive to work and something in the rear grabbed till i was almost stopped then released i went about a half block and it grabbed again till almost stopped and then released again. tryed pulling fuse for abs still the same. haven't managed to move more than a few blocks before it starts.
You said your brakes look fine... did you also check the parking brake?? You may have had a lining separate. Hopefully it's not a differential problem, doens't really sound like it.
You said the tranny fluid was changed recently, was the correct fluid used? I had an old caddy that did something similar, a tranny seal blew out and it felt like the brakes were locked up. I could give it gas but it woudn't move.
yeah it was correct fluid weird thing is it grabs while you're moving just until you're about stopped than releases . repeats this about every half ablock
