4spd question
Old Jun 27, 2002 | 06:24 AM
mudrider's Avatar
mudrider
4spd question
I need a 4 spd transmission that will bolt up behind a 460. it is in a 78 f-150 4wd. What kind of donor truck do I need to look for. Can you change bellhousings on a Ford man trans. Sorry for so many questions but This is my first Ford.
Old Jun 27, 2002 | 10:39 AM
jaysonb's Avatar
jaysonb
4spd question
Welcomt to FTE!
You need to look for a late 70's donor that has/had a 351m or 400. This engine family has the same bell housing bolt pattern as the 429 and 460. Your tranny choices are either the T-18 or NP 435. Both are good trannies, but most folks favor the NP 435. Also, ther is a company called L&L Perf. that makes all kinds of adaptor kits, headers, etc for putting a 460 in your truck. Good Luck!
Jayson
Old Jun 28, 2002 | 08:40 PM
Mike W's Avatar
Mike W
4spd question
You could go with a ZF 5 speed. This one does not have a separate bellhousing. Is kind of pricey.
Old Jun 28, 2002 | 09:16 PM
794wd's Avatar
794wd
4spd question
Hello,I have a np 4speed out of a 1979 ford that will mount to a 429/460 i also have the bell houseing and the t-case.But before i can sell this i have to see if this other t-case will mount to an aod i have b/c if it dont i will use the 4 speed and t-case in my truck.I will find out tuesday and if this other t-case works i will let you know if your interested in the 4 speed bellhousing and t-case let my know the t-case is a np 205 let me know
Thanks Brandon
Old Jun 30, 2002 | 06:47 AM
mudrider's Avatar
mudrider
4spd question
Thanks for all the help
Old Jun 30, 2002 | 03:11 PM
villagidit's Avatar
villagidit
4spd question
