muffler delete
Old Sep 30, 2005 | 12:32 PM
bhiggins's Avatar
bhiggins
muffler delete
who sells a muffler delete pipe for the stock 3.5 inch pipe?
i've seen 3's and 4's but not a 3.5
any help would be appreciated
Thanks
Brandon
Old Sep 30, 2005 | 04:13 PM
ricky4fingers's Avatar
ricky4fingers
This is where I got mine: http://www.mandrelbending-tubefabric...com/index.html. I gave them a call and told them my truck/trim level etc...got a delete pipe that was mandrel bent and fit the stock system perfectly...
Old Sep 30, 2005 | 07:21 PM
bhiggins's Avatar
bhiggins
thanks ricky what did it cost you?
anybody else?
Thanks
Old Sep 30, 2005 | 08:46 PM
BuickTurbo's Avatar
BuickTurbo
Well, any autoparts store should have some straight stock in 3.5". If not go to your local "sketchy" muffler shop and ask to buy a straight peice of pipe.
Old Sep 30, 2005 | 08:51 PM
buckshot047's Avatar
buckshot047
muffler delete
just go to your local big truck shop and ask for a 4 ft piece of 3.5 ID..go to the local muffler shop and tell the to cut the hangers and put new ones on ar weld the cut ones to get it to fit...sounds great just did mine this week...only thing is I saw my mileage go DOWN!!!!!!!! that sucks!
Old Sep 30, 2005 | 08:54 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
that is PROBABLY because you knew you were doing a modification that would add a sound that you particularly liked. therefore, you sub-conciously used more pedal than you have before. in real life driving, a straight pipe reduces back pressure, which will increase mileage and give marginal HP/tq. gains.
Old Sep 30, 2005 | 09:06 PM
buckshot047
muffler delete
yeah Im thinking thats it sounds too damn good....we will see what happens when the Predator goes in!
Old Sep 30, 2005 | 09:39 PM
claydr54's Avatar
claydr54
Get a piece of 4" and slide it over the 3.5"!
Old Sep 30, 2005 | 10:23 PM
PowerstrokeJunkie
no, that will not work! the wall thickness of the pipe is not 1/4'', therefore the OD of the pipe will not be 4''. it is closer to 3.6''. best to get a regular 3.5'' pipe and get a muffler shop to flare one end for you. or both if you arent sliding it into a already-flared end.
Old Oct 1, 2005 | 12:41 AM
jlande's Avatar
jlande
Auto Jet Muffler out of Des Moines sells them - they gave me part#FLD350MRP2K, with a price of $50.60 + shipping.
http://www.auto-jet.com/
Old Oct 1, 2005 | 11:23 AM
MRBASS's Avatar
MRBASS
I went to my local muffler shop and they cut the muffler off and added a piece of straight pipe for 30 bucks,,, 3.5" Pipe is more common than you might think.
Old Oct 1, 2005 | 03:30 PM
bhiggins's Avatar
bhiggins
Angry
i thought this would be simple too but every local muffler shop around here says 3.5 is an odd size and we can put a piece of 3 in there for $50
or our benders don't flare that big
what ever the excuse i'm getting agravated at the LOCAL muffler shops
