programer/chip
Old Sep 29, 2005 | 10:08 PM
nikates's Avatar
nikates
programer/chip
is it bad to stack both a programer and a chip on a truck
Old Sep 29, 2005 | 10:14 PM
1997F-350's Avatar
1997F-350
i dont think you can. one will override the other.
basically from what i understand is:
a chip/ programmer when installed will overide pcm. so if you do that and then add another it will cancel one of them out. i could be wrong but i am pretty sure.
also why waste that much money. for the cost of one you could be 1/2 to the purchase of a set of aftermarket injectors.
Old Sep 29, 2005 | 10:20 PM
nikates's Avatar
nikates
on my 2000 dodge i stacked a procomp edge and a superchip programer and it increased power a lot more then when i put my 110horse bd injectors init with the edge
Old Sep 29, 2005 | 10:27 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
A chip will always overwrite the PCM. Doesn't matter if it's a tuner or stock, once you install a chip that's your programming.
You can stack external fueling boxes on to either a programmer or a chip, produces similar effects as the stack on your Dod*e.
Old Sep 29, 2005 | 10:36 PM
nikates's Avatar
nikates
The EZ can also be used in conjunction with a chip or "stacked" with most OBDII programmers. http://www.dieselperformanceparts.co...unique=EZF1000
Old Sep 29, 2005 | 10:41 PM
cookie88's Avatar
cookie88
FTE Emeritus
Right...the EZ is an external device, so is the Banks six-gun or any of the dozens of variations of the 10K mod...like the 18k from black cloud diesel.
Old Sep 29, 2005 | 10:44 PM
nikates's Avatar
nikates
which is better banks or edge with super chip 1705
Old Sep 29, 2005 | 11:12 PM
ltfox's Avatar
ltfox
IMHO A good chip from say Tony Wildman or Jody Tipton will give you as much as a buying 2 seperate products at half the cost. Plus with a multi pos chip you have several different settings at the touch of your fingers. A chip will give better power gains than any tuner at least with a OBS powerstroke. My .02cts
