no power?
Old Sep 29, 2005 | 08:52 PM
66 Ford's Avatar
66 Ford
Question no power?
hello i have a 2003 f-350 with the 6.0 and yesterday i had a good amount of weight in the back and left it at the job site and today when i went to come home with it it like had no power like it would not get out of its gear if u follow me? when i was doing like 70 it would go strong untill it don shifted and then there was nothhing and i know the other day that it would pull hard any one know what i am talking about or what could be wrong? thanks stephen
Old Oct 10, 2005 | 07:49 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Let's bump this up and find an answer for you~!~
Old Oct 10, 2005 | 07:57 AM
Kwikkordead's Avatar
Kwikkordead
I would start with replacing the fuel filter. If that doesn't work then you'll have to get it diagnosed. Electronically controlled engines, whether they be diesel or gas powered engines need to be data-logged to properly diagnosed and repaired.
Old Oct 11, 2005 | 04:13 PM
scott d smith's Avatar
scott d smith
I have had similiar problems with mine. I have the same vehicle. My problem was due mostly to carbon buildup. Lucky for me I have an extended warrenty. My symptoms were lots of black smoke at low RPM and severe loss of power until the turbo wound up which took a while.
EGR valve bad replaced, 2 injectors bad and replaced, Turbo actuator valve bad replaced, turbo bad replaced.
I am still not convinced that my truck is performing as well as it should be.
If you get your truck diagnosed be persistant. It took me several trips to the dealer to convince them that I had a deeper problem than they thought.
My truck still blows black smoke occasionly(lots of black smoke). I turn the truck off and them start again and all is well. Is this normal?? I sorta do not think so.
