1978 - 1996 Big Bronco
Brake lines?
Old Sep 29, 2005 | 08:46 PM
MBBFord's Avatar
MBBFord
Question Brake lines?
I'm lifting my 79 Bronco 6" and I was wondering what all I need.
I'm thinking about 7" extended brake lines up front, but do I have to put any lines out back?
Any comments are appreciated, also what have ya'll put on your own truck(combinations of line combos).
Old Sep 29, 2005 | 09:30 PM
greystreak92's Avatar
greystreak92
Not completely certain about the earlier models but I know the later models require extending the two front lines AND the rear flexible line from the frame to the axle housing. I should think this would be the same scenario for your 79 as well.
I went up 4" and extended the lines 6" just for a bit more s-t-r-e-t-c-h at full drop.
Old Sep 29, 2005 | 10:42 PM
MBBFord's Avatar
MBBFord
There are 2 rear flexable lines from the frame to the axle if I remember correctally, but I'm not 100% sure.
Thanks for the info grey, so 7" should be ok for the front, and I need extended lines for the rear to right?
Any companys better than others?
