automatic climate control
Old Sep 29, 2005 | 04:20 PM
nymets78's Avatar
nymets78
does anyone know why the A/C always comes on when the AUTO button is pressed and if that means the A/C compresser is always running. It won't come on if it is really cold outside, but most of the time it does. It is a 2004 model.
Old Sep 30, 2005 | 07:41 PM
vicv's Avatar
vicv
A fellow Mets fan! I have the auto climate control on my 97 Sable. It's not a truck but I'll guess that the system is very similar. The auto button will engage the a/c all the time if it is working correctly. My guess is so that it can constantly adjust the temp to the set level and keep the humidity down. The a/c won't come on if the outside air temp is below a certain level, I forget the number but I want to say 60 degrees.
Old Sep 30, 2005 | 08:53 PM
CanadaGuy's Avatar
CanadaGuy
You have to select the panel or floor mode buttons to have the compressor not run. It will still operate as automatic as long as you don't touch the fan control.
79 bronc
18
Apr 27, 2011 09:34 PM
pete315
Jun 8, 2010 07:42 AM
HorseyHauler
Aug 10, 2007 04:05 PM
Keith460
Apr 22, 2002 09:56 AM
