I have a 66 f100 I put power steering on and I used the gear box and column out of a 79 f150 I was wondering if someone had a diagram on the wiring?I thought i seen it on here a long time ago, but ran some searchs and couldn't find it. thanks for any help
if you used a 79 column, I would think you would need to inquire on the 73-9 group for that....I havent seen anything like that on here myself however.
66, I copied and saved this, probably from this site, I am not the author nor know who he is. I will repost it, and hope it helps.
John
67-72 steering column pin out.
Big Connector:
White/Blue stripe: Right Front Turn Signal/Indicator on Instrument Panel Green/White Stripe: Left Front Turn Signal/Indicator on Instrument
Panel
Blue/Yellow stripe: Ground When horn Depressed
Red/Black Stripe: Brake Pedal Switch (12 VDC when brake pedal is depressed.
Blue: Turn Signal Flasher (Provides 12 volts to Turn Signals) Little Connector:
Green: Right Rear Turn Signal/Stop Lamp
Yellow: Left Rear Turn Signal/Stop Lamp
Connect the following color wires together.
White/Blue Stripe on steering column: Connect to White/Blue Stripe on big connector Green/White Stripe on steering column: Connect to
Green/White Stripe on big connector Black/Red Stripe on steering column: Connect to Red/Black Stripe on big connector Blue on steering
column: Connect to Blue on big connector Yellow/Black Stripe on steering column: Connect to Green on little connector Light Green on
steering column: Connect to Yellow on little connector
I put in a steering column from a '79 into my 66 a couple of years ago, and made a little diagram using MSpaint. If you send me your e-mail address I can forward it to you, or if someone can tell me how to post it, I will. personal e-mail is awright840 at earthlink.net
Hello awright840!
I have a '65 that I'm putting a '79 Tilt Steering Column in and would really appreciate your wiring diagram. Would you please email me a copy. My email address is: mjdavid48@highstream.net
Thanks a million!!!!!!!!
You are absolutely right. The family and other projects have kept me from reading for several weeks now, but I did get a personal e-mail from him and sent him the schematics. Hope it helps. If anyone else wants a copy, please let me know. I have switched internet providers from earthlink to verizon, but the rest of the e-mail address remained the same.
