Aerostar Ford Aerostar
please help
Old Sep 28, 2005 | 11:04 PM
rikson's Avatar
rikson
please help
96 aerostar rear hatch will not open think it is jamed can not open how can i get the hatch open thanks removed rear panel and checked inside can not see much leaver seem to work latch moves when hit by striker rod
Old Sep 28, 2005 | 11:26 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old Sep 29, 2005 | 10:24 PM
93nighthawk's Avatar
93nighthawk
Welcome!
You are half way there. You will need to spray the latch with some lithium lube and let it sit for a while. Then use a pair of pliers to gently pull on the release rod to open. Once open, finish lubing the latch.
But before anything, is it locked? If so, Try to unlock it from the inside.
DaveinTulsa
Nov 17, 2014 01:11 PM
CLINT-THE-GREAT
Feb 14, 2013 08:17 PM
garrickg
Aug 26, 2011 04:13 PM
barljos13
Feb 14, 2011 04:27 PM
