C6 Transmission Tailshaft Question
I have a 1995 Ford Ranger 2wd. I'm installing a 351W w/ C-6 trans. Ok the transmission came from a 1984 Ford Bronco Full Size 4x4 I want to make the trans 2wd. It had the adapter between the transfercase and the transmission. Is there a "short" tailhousing for the C6 trans or is there only a 13 1/2" tailhousing? If there is a shorter housing does anyone know where I could find one or how to go about looking for one? ie: what vehicles it came on etc., or am I doomed to tear down the trans and change out the output shaft? Any help would be immensly appreciated. Thank you for your time,
Mike
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
…Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
