C6 tailshaft bushing replacement
Old Sep 28, 2005 | 04:54 PM
83Van's Avatar
83Van
After much reading and some inspection I've realized the tailshaft bushing in my '83's C6 transmission needs to be replaced [vibration at speed, rear seal popped out twice, play in output shaft]. Is this something that can be done without pulling the trans and/ or specialty tools?? Any guidance MUCH appreciated!!
Old Sep 30, 2005 | 08:02 AM
83Van's Avatar
83Van
bump...anybody have a clue on this?? Would like to do the repair myself but need some specifics
Old Sep 30, 2005 | 03:54 PM
jtmerritt's Avatar
jtmerritt
Isn't the C6 tailshaft one that can be removed from the tranny with the tranny installed in the vehicle? I thought it was. If it is then you can either repair it or possibly get a replacement from a bone yard.
John
Old Sep 30, 2005 | 08:39 PM
rclarke's Avatar
rclarke
If you pull the extension housing you can saw cut and remove the old bushing. Driving or pressing the new bushing into the housing requires a bit of care to replace it without damage. Then install a new seal and use a new gasket to replace the housing on the transmission.
53fatfndr
Sep 8, 2021 10:27 AM
flaboy1979
Dec 22, 2013 06:12 PM
genscripter
Feb 6, 2013 04:18 PM
michaelbrainardatwor
Sep 7, 2005 02:16 PM
