White smoke/ruff running.
Old Sep 28, 2005 | 03:19 PM
iderby93's Avatar
iderby93
Question White smoke/ruff running.
I have a 1997 F-250 PSD, I have replaced the glow plugs, relay, and the temp sensor and it still smokes on cool morning start-up and runs ruff untill warm. wait light goes of right away and I tested the relay and it also goes off right away. Please help, I am getting frustrated. ps. read somthing about a glow plug control module any ideas?
Old Sep 29, 2005 | 07:16 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
…Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 29, 2005 | 07:45 AM
lancekilgore's Avatar
lancekilgore
could it be the quaility of fuel you are using? how many miles on the truck.
Old Sep 29, 2005 | 07:48 AM
lancekilgore
could it be the quaility of fuel you are using? how many miles on the truck. White smoke on a diesel means you are pushing to much fuel or it's unburned fuel. how are your glow plugs working IE are you geting power to them? should be simp,le enough to check wilt a multi meter on volts.
Lance
Old Sep 29, 2005 | 09:29 AM
iderby93's Avatar
iderby93
I am running good fuel Tested everthing, I need to know what keeps the glow plug relay on for extended periods during cold weather.
Old Sep 29, 2005 | 10:43 AM
lancekilgore
This may not help because I don't know exactly what sensor works the glow plug sensor, but in all the desel systems I have worked with with a glow plug system there is a temp sensor that keeps the glow plugs working untill the engine warms up. It is also linked to a main brain that works.
When the temp sensor sends the temp to the main brain and the engine temp is cold, the brain sends signal to the relay to start working the glow plugs. and it keeps working the glow plugs until the engine warms up. I know the gm desel system in dept but not to much of the ford but they all work under the same priciple. My two cents
Lance hope it helps
Old Sep 29, 2005 | 11:35 AM
touchofgrey's Avatar
touchofgrey
White smoke usually indicates coolant. Blue indicates oil. And Black indicates fuel.
I'd take the truck to a diesel shop and have them run a compression check. Keep in mind that a compression check on a diesel isn't the same as a gasser. It needs to be done by someone that majors in diesels. Hope this helps.
Old Sep 29, 2005 | 11:54 AM
chapguy's Avatar
chapguy
Sounds like your glow plug system isn't communicating well. Try jumping across the two brass posts on your relay before firing it up and hold it for 10 seconds or so. (It gets very hot so be warned). Then fire it up and see if you have an improvement. If so, your relay may still be bad or it could be the wrong one.
Old Sep 29, 2005 | 12:58 PM
lancekilgore
Touchofgrey, in a diesel white smoke means to much fuel or unburned fuel. I see it every day during the winter with my fleet of hummers when the glow plugs are not working. You have to pull the injectors to do a compression test on a deisel, or use the special cpu that will tell you automatically, like doing a compression unballance test whitch takes about ten min as opposed to pulling alll injectores then testing and puting them back. 4 to 5 hours. by testing with a multimeter at the glow plug it will tell you wheather there is power there or not to activate the glowplug.
as well as oftern we get deffective glow plugs from the manufacture.
Lance
Old Sep 29, 2005 | 01:23 PM
touchofgrey
Lance
I'm afraid that a broad statment as "in a diesel white smoke means to much fuel" isn't always right. We both are correct.....in the fact you are discribing a winter time occurance, and I stated "usually indicates coolant". He is in Ohio, and I don't think it's too cold up there yet. And I believe steam is steam, and it usually is white. I'm not certain as to which problem he has......that's why I suggested a compression check. Would he even get it started if the glow plugs were out? I've never tried it......just curious.........but he has already replaced them anyway. I do agree with you, that you can get bad glow plugs from the parts counter though.
Old Sep 29, 2005 | 01:27 PM
touchofgrey
I forgot to ask........are you losing any coolant? That would lay my theory to rest if your not.
Old Sep 29, 2005 | 01:40 PM
iderby93's Avatar
iderby93
No, I am not loosing any coolant and the oil level is right on with no loss, I think its in the relay not staying on long enough.
Old Sep 29, 2005 | 02:03 PM
touchofgrey
Your probably right.
Old Sep 29, 2005 | 02:25 PM
lancekilgore
Ok I'll agree with the white smoke could be coolant. I guess you could classify it as white smoke at start up is normally fuel and once warmed up would be coolant. beleive it or not there is still a cpu that operates the relay. could be as much as just a circiut board plugged in under the dash. or as big the main brain that operates the vehicle.
Old Sep 29, 2005 | 02:45 PM
touchofgrey
Oh yes.......technology marches backwards once again. What ever happened to the "KISS" way of doing things? LOL
