I Have A 93 Bronco With Automatic Transmission. When I Last Went To Put It In Drive The Gear Lever About Fell Off The Steering Column. I Have Taken The Steering Column Housing Off To Get A Better Look At Where The Problem Is, But It Isn't Juming Out At Me Right Away. I Looked At A Generic Parts Diagram For The Transmission Linkage And Don't See Exactly Where I Should Be Tracing The Problem To.
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
…Enjoy FTE and The State Chapters are located at the bottom of the main forum page. JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
If your shift lever moves freely it may have become disconnected down at the tranny. There should be a rod from the column to the tranny that connects to a float piece coming off the tranny itself. (man I hope that was clear) Try following the rod up to make sure it hasn't become disconnected somewhere along the line.
