weatherstrip glue
Old Sep 28, 2005 | 07:12 AM
uk1050's Avatar
uk1050
weatherstrip glue
havent really shopped around for any yet so i will ask all of you. getting ready to buy some glue for the door rubber. whats the best. i chopped the top so the rubber is going to have to be cut and put on in pieces so i need something good. thanks.
Old Sep 28, 2005 | 07:16 AM
ferguson777's Avatar
ferguson777
3M
I think the part # is 88088 or something like that. Description is - "weatherstripping adhesive". Comes in a red and white tube like toothpaste only bigger.
I can check the part # at home tonight............
Put it on the door/whatever and on the weatherstripping. Let it set up for about 15 minutes, reaply a thin coat on the weatherstripping again and put it in place......
Old Sep 28, 2005 | 07:48 AM
GreatNorthWoods's Avatar
GreatNorthWoods
3-M also makes a spray weatherstrip adhesive which I have used successfully. In addition to weatherstrip it can be used to attach the rolled aluminum insulation. I don't know the part number. If you stick with any of
3-M's products I don't think you can go wrong.
Vern
Old Sep 28, 2005 | 03:38 PM
fking1's Avatar
fking1
Originally Posted by ferguson777
3M
Agree. Is what I used. Works great. Comes in black or yellow.
Fred
Old Sep 28, 2005 | 03:48 PM
Brian_B's Avatar
Brian_B
3M
Completely agree. Thats what we use for all kinds of things on vehicles (trim, emblems, etc.) not just weatherstripping. 3M makes good stuff.
Odd name though....minnesota mining and manufacturing.
Old Sep 28, 2005 | 05:28 PM
ferguson777
O.k.,
3M part # 08008
description is "super weatherstrip adhesive"
and 08008 gets you the manly black colour.
You should be able to get it through any really good autoparts chain.
The tube is big enough to get through one F1 and a 58 Cadillac 4 door, maybe two. (no I don't have a 58 Caddy, I don't have Axracer's money).
There ya go,
Old Sep 28, 2005 | 05:42 PM
AXracer's Avatar
AXracer
yellow! affectionately known as "gorilla snot"! Do yourself and your fingers (and some other parts you might touch) a favor and pick up a container of weather stripping adhesive remover when you pick up the adhesive, it can become a big mess in a hurry.
Old Sep 28, 2005 | 10:56 PM
Phoenixson's Avatar
Phoenixson
Smile
Ax, you crack me up! That's why I read your posts! Plus every once in a while, I learn some.........thing.
Old Sep 29, 2005 | 01:30 PM
Jag Red 54's Avatar
Jag Red 54
Sorry Ax, but I have to dissagree. Use the black. The yellow peeking out from behind the rubber is very obvious and a little tacky. (Pun intended) I would only use the yellow on a yellow vehicle. I wish every after-market product worked as great as 3M's adhesive. Good luck, Jag
Old Sep 29, 2005 | 02:02 PM
AXracer's Avatar
AXracer
I was only refering to the yellow color giving it it's common name, it was the only color it came in until fairly recently. I too use the black. When I didn't see it on the shelf with the adhesives at my local NAPA store I asked where it was. The clerk asked if I wanted such and such or "gorilla snot", he knew it by the same name!
