blower relay got hot-melted socket
Old Sep 27, 2005 | 09:35 PM
jchea650's Avatar
jchea650
I have a 92 E-150 van and the blower doesn't work at all. I hooked it directly to the battery and it works perfectly fine in all speeds. So, I found the blower relay and the relay was melted as well as the socket. The relay is found in the power distribution box under the hood on the driver's side. I put a new relay in the socket, but the blower still doesn't work. I am sure that it is not getting a good connection. So back to my question. Is it possible to pull the old socket out or is the whole box one piece? It looks that I should be able to take out the old socket and rewire a new one either in the same place or off to the side. Is this possible? I need some help! Thankls.
Old Sep 28, 2005 | 10:03 AM
goofy173's Avatar
goofy173
I use a small file to clean the connections in the socket. You don't want to spread the prongs in there much so the file needs to be the size of one of the blades that normally goes into that socket.
mcn420
1997 - 2003 F150
Oct 9, 2014 04:47 PM
tabijan
Jul 7, 2014 10:32 PM
dockwatson
Mar 12, 2014 08:42 AM
chuckers98
Electrical Systems/Wiring
13
Feb 14, 2010 10:50 PM
MOK-
Escape & Escape Hybrid
Apr 21, 2008 12:06 PM
