'05 coil overs on a 78 f-250???
anybody ever seen or done a coilover swap on a early model f-250 (78 model) im either curious or nuts. i have been having thoughts about a swap eversince the new superdutyies came out and all the aftermarket lifts for them. my mind has been running about how to fit one to my truck. seems like it might work out pretty good with a little bit of welding and cutting. heavy duty is heavy duty right???????
they so stock but some of the aftermarket companies are using coilovers and a fourlink system in the fromt like skyjacker. it looks pretty stout and if it can handle a superduty im sure it can handle a 78 f-250. im seriously thinking about doing this. ill just have a little fabrication to do. wish me luck.
just to get our terminology straight here a coilover is a combination of a race shock and coil in one unit. it uses a standard racing spring mounted on a threaded spring seat for ride height adjustment, and the shock resides inside the spring. springs are available in any rate and any length thus allowing a complete customization of the suspension.
as far as i know there are no stock ford trucks that come with the coilover option... i'm prolly wrong but i have never heard nor seen it. i think they are all just coil/radius arm setups
-cutts-
-cutts-
-cutts-
-cutts-
http://www.fordvehicles.com/trucks/f150/features/specs/
Front suspension Independent double-wishbone with coil-over shock and cast aluminum lower control arm
Rear suspension Leaf spring/solid axle
Front and rear shocks Heavy-duty gas-pressurized
Brakes Power 4-wheel anti-lock disc
Steering Power
F250/350 specs
http://www.fordvehicles.com/trucks/s...eatures/specs/
CHASSIS SPECIFCATIONS
Front suspension Twin I-Beam with coil springs and stabilizer bar (4x2), Twin-coil monobeam with coil springs and stabilizer bar (4x4)
Rear suspension Leaf spring/solid axle with stabilizer bar (DRW, optional SRW)
Front and rear shocks Staggered heavy-duty gas-pressurized
Brakes Power 4-wheel disc anti-lock
Steering Power steering
yes your right about the coil springs and radius arms on the superduties in stock trim but i am talking about the aftermarket lifts. i.e. not stock. fabtech sells a kit that includes a coilover upgrade kit in its lift kits for the new sd's you can check on their website www.fabtech.com. i do not want the stock suspension system on the 05's while it is good it is to low lol. im just wondering if anyone has heard of sombody thinking about doing a coilover setup on a late 70's f-250/350 i have heard about them on the f-150s but im not interested in that. usually they just use the kits for broncos which are not as heavy duty as i would like. if i just wanted coils i would go with a bronco lift kit that would be easy!
