Hi I need help
Old Sep 27, 2005 | 05:21 PM
khof's Avatar
khof
Hi I need help
I have an 01 sport trac. My rear window is stuck down, the power supply is good so I think that it's the motor. Does anybody know if the motor can be removed with out taking out the cables or how to get the window back up manually?
Old Sep 27, 2005 | 05:25 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old Sep 27, 2005 | 08:06 PM
therealulysses's Avatar
therealulysses
On my '91 i removed the door panel and got a 12 V battery and 2 clip leads, disconnected the wiring to the window motor, hooked up the battery, and up it went. But in my case my window motor was still good.
