Speedometer Gear
Old Sep 27, 2005 | 09:08 AM
1954blueoval's Avatar
1954blueoval
Speedometer Gear
Does anyone know where to get speedometer gears for the original three speed manual transmission? I changed my rear end and now I need a 15 or 16 tooth gear, but the smallest I have been able to find is 19.
Old Sep 27, 2005 | 11:19 AM
barry's Avatar
barry
The smallest gear listed for your 3 speed is a 18 tooth gear. It's 01T 17271-A. In the same chart they list the gears for the 4 speeds. They should work. I found a 15 and a 16 tooth listed.
16 tooth TGAA 17322-C
Atkins Motor Co. Atkins, MN. 1-800-793-9010
Dennis Carpenter 1-800-476-9653
I also found the 2 others ( 15 and 18 tooth ) . If you want the locations, let me know.
Barry
50 F-1
Old Sep 27, 2005 | 05:09 PM
AXracer's Avatar
AXracer
Do you have a local speedometer shop? They usually stock a wide range of gear ratios and even external ratio changers. The one here puts the vehicle on a roller and can give you an accurate reading speedometer.
Old Sep 27, 2005 | 08:26 PM
54 gene's Avatar
54 gene
I got mine at www.midfifty.com they will have anything you will need have fun and keep us posted.
