My 1984 F-250 uses a 8 x 6.5 bolt pattern. I would like to upgrade to some better looking "take-off" alloy wheels... But now they are 8 x 170mm. Will the metric wheels work on my hubs?
Help! I need to loose the "steelies" and the "dawg dish" caps. What will work that'll look good?
I'm not sure on 3/4 ton axles but I know that the 5x5.5 turned "metric" in 97, but they were still the same size as 5x5.5 so the rims were interchangable. I would assume the same for the 8 luggers, but second opinions are always nice.
Are these the original 8 bolt off white OEM rims that you want to replace?
