Headlight Lens Replacement ?
Old Sep 26, 2005 | 05:53 PM
rabbithutch's Avatar
rabbithutch
Can the lenses on headlights be replaced without replacing the entire headlight assemblies?
My '90 F150 (had it a week, already) has lenses that obscure some of the light from the halogen bulbs. It seems like there's a film on the lenses, but I suspect that it's just distortion from 15+ years of abrasion from dirt, dust, etc.
Being the cheapskate I am, I'd prefer to replace just the lenses and not the whole assemblies (assuming it is possible and that separate lenses are available). I took a look at them yesterday and found the lenses fastened only by some type of sealant that appears to have dried and partially fallen out over the years.
If this is a reasonable approach, could someone tell me where to get the lenses and how to remove the assemblies so as not to damage anything during the process?
TIA
rh
Old Sep 26, 2005 | 06:01 PM
tjc transport's Avatar
tjc transport
i ain't rite
nope. 1 piece units. you replace the whole light assembly or nothing. they are sealed units to keep moisture out
Old Sep 26, 2005 | 09:30 PM
mike2112's Avatar
mike2112
Unhappy
They'll cost you about $150 a pop. Ouch. I have the same problem on my '87 and it's killing me just thinking about it.
Old Sep 26, 2005 | 10:10 PM
Dieseldan7.3's Avatar
Dieseldan7.3
They are around 100-120 for a damn headlight. Makes you wish you had an old pickup with the glass headlights you replaced for $7-8. They arent exactly bullet proof either.
Old Sep 26, 2005 | 10:24 PM
nascar88ford's Avatar
nascar88ford
Once you put those new one's on it makes a world of difference, especially on a rainy night. Easy to do.
Old Sep 27, 2005 | 02:34 AM
polarbear's Avatar
polarbear
Check with aftermarket parts- should run about $40/ea. Or... sometimes some mothers polish will clear up the cloudy lenses.
Old Sep 27, 2005 | 06:55 AM
karljay's Avatar
karljay
I had the same problem, used 1000 grit wet/dry sand paper and wet sanded it till it was white. Followed up with rubbing compound on a polisher and it now looks 500% better!
Old Sep 27, 2005 | 10:32 AM
MemOrex's Avatar
MemOrex
eBay....you could probaly get a brand new, diamond clear pair for $100.
Whitey Ford
Feb 22, 2012 08:42 PM
Gramps86
Nov 13, 2010 02:58 PM
sumdumgai
May 3, 2006 09:55 AM
Mark 42
Electrical Systems/Wiring
Jan 11, 2005 01:53 PM
DanMan7
15
Aug 19, 2004 01:07 PM
