I was wondering if anyone knows if there is ANY websites out there or where i can find paint code numbers from 67-79 ?? If u can email me or talk to me it would be much appreciated!!
There is a scan of my 79 Ford manual at the link below. http://y42.photos.yahoo.com/bc/ecarter50/vwp?.dir=/My+Photos&.src=ph&.dnm=Ford+paint+codes.gif&.view= t&.done=http%3a//y42.photos.yahoo.com/bc/ecarter50/lst%3f%26.dir=/My%2bPhotos%26.src=ph%26.view=t
I don't know about a website, but I have some manuals that list most of the paint codes for 67-72. Unfortunately, they don't list them all, which I know because none tell me what my 69 "D" code is (I think it is the color listed in the brochure as "empire yellow", but that still doesn't help my body guy any). Post the code you want deciphered and I'll look it up for you. In the meantime, if anyone has better info on what a 69 F100 "D" paint code means, let me know.
JJ: You must be do'in' something wrong, pal. I looked up my paint code on paintscratch.com (THEN I found it on my truck), I ordered a can of spray paint, a two-oz bottle of touchup. When I gottem, I tried them - dead on! Or as they say back home - If it'da been any gooder, I couldn'ta stood 'er.
They do have Ford trucks (at least they did a couple of weeks ago); try the site again.
Raul
w/ 81 F-100, I6, SROD, Carter 1V non-feedback carb, no A/C, no PS, no PB, but it gets me where I need to go
Paintscatch.com does not have listings for 67-72 Ford trucks. They may have them for later model trucks, but that far back all they list are Mustang color codes (which in some cases, but not all, are the same as the truck codes).
Here's the listing from my 69 shop manual (code - spec number - color name):
A - 1724-A - Black
B - 3059-A - Royal Maroon
C - 1525-A - White
E - 1906-A - Lt. Blue
F - 1226-A - Lt. Blue
G - 1526-A - Chrome Yellow
J - 1515-A - Red
L - 1237-A - Dark Green
M - 1619-A - White
N - 3282-A - Dk. Green
P - 3150-A - Med. Ivy Green Metallic
Q - 1624-A - Med. Blue Metallic
R - 3125-A - Lt. Ivy Green
T - 2008-A - Red
U - 2097-A - Med. Green
W - 3120-A - Yellow
X - 1742-A - Med. Blue
Y - 3216-A - Med. Aqua
2 - 3071-A - Lt. Ivy Yellow
3 - 1635-A - Gold
4 - 3069-A - Lt. Ivy Green Metallic
6 - 1631-A - Lt. Beige
7 - 2098-A - Med. Blue
Of course, my truck's plate code (D) isn't listed. If anyone has a source that gives the M-30J/M-32J spec number for a 69 "D" color code, please let me know.
ksd
69 F100 Explorer lwb 2wd FE 360 C6 3.25:1. WANTED: straight/clean styleside long box w/aux fuel tank for 67-69 F series.
If it REALLY is missing, I wonder if it came out of the factory only in Primer because they wanted a special paint later?
Are there a bunch of letters/numbers around the DSO code?
There are a bunch. I have been using your site to try to decipher them. Here's what it looks like. I'm still unsure of the meaning of the absent Exterior Paint Code and Front Axle Code. I haven't found a reference to Decipher the Interior Trim (DAM) and the Special Order Codes (1218). My last query is why the heck does it say Made in Canada on the door VIN?
Off Door VIN tag
1) Truck Series Code - X36 (Supercab F350 4x4)
2) Engine Code - S (400 2v)
3) Assembly Plant - K (Kansas City)
4) Sequential Serial and Warrenty Number - FAxxxx (Jul '79)
5) Max GVW - 8600
6) Wheel Base - 155
7) Exterior Paint Codes - None Indicated
8) Model Code and GVW - X361
9) Interior Trim Seat and Body Cab Type - DAM (Unknown)
10) Transmission Code - K (C6)
11) District/Special Order Codes - 741218 (Seatle/UNKNOWN)
12) Rear Axle Codes - B4 (Dana 60 Limited Slip)
13) Front Axle Codes - None Indicated
The number after the District Code is the D.S.O. consecutive unit number. It just tells you it’s the Nth special order for that particular district. When the truck was new they put a blue envelope in the glove box for the customer with that number on it and listed all the special order options that it came with. The dealer got a white envelope with the same info inside and kept it on file for future reference.
That's strange..... My interior exterior paint is a bright yellow.... and the interior is black and grey. There is no sign of anything that is close to being red. The shipping invoice for my pickup incl.
F361 155 CUST STYLESD SUPERCAB
WITH 4X4 OPTION
SPECIAL PAINT
6.6L ENGINE /400 8 CYL/
RANGER PACKAGE
SEAT TRIM - KNITTED VINYL
GUAGES - AMMETER & OIL PRESS.
WINDOW - SLIDING REAR
TOOL STOWAGE BOX
EXHAUST SYSTEM - REDUCED SOUND
LIMITED SLIP REAR AXLE
MIRRORS - LOW MOUNT - BRIGHT
BOX COVER - STD W/SLIDING WDO
MOULDINGS -VINYL INSERT
AIR CONDITIONER
SUPERCAB REAR SEAT - BENCH
RADIO - AM/FM STEREO
CAB LIGHTS
LIGHT GROUP
GLASS TINTED - ALL AROUND
SECURITY LOCK GROUP
OIL COOLER - AUXILERARY EXT.
COOLING PACKAGE - SUPER
FUEL TANK-LH FRM W/AFT OF AXLE
SHOCKS-HD FRONT AND REAR
BUMPER - REAR STEP PAINTED
4 9.50X16.5 E 10PR
SPARE WHEEL 16.5 X 6.75 W/CARR
/4/ MUD AND SNOW TIRES
SPECIAL ORDER 74 1218
SPECIAL PAINT NC
TOTAL OPTIONS
