Hood Vibrates
Old Sep 26, 2005 | 03:17 PM
knutson's Avatar
knutson
Question Hood Vibrates
i've got an 05'screw lariat that the hood seems to fluctuate when i'm driving at hwy speeds,go over bumps or am trailing semis...yesterday was pretty bad i thought it might pop up. anything i can check out to make sure it is indeed secure what should i look for???
Old Sep 26, 2005 | 04:03 PM
HOLESHOT1's Avatar
HOLESHOT1
My '04 scab FX4 does it a little too. I remember way back in a thread, someone had mentioned it possibly has something to do with a bug shield. (if you have one). I have the factory F150 low profile shield on my truck, but I can't honestly remember if the hood vibrated before I put the shield on. It's not that bothersome to me to remove the bugshield and try it both ways. I really don't think its harmful. Just check hood mounts or hinges once in a while.
Old Sep 26, 2005 | 04:24 PM
knutson's Avatar
knutson
no bugshield
Old Sep 26, 2005 | 04:27 PM
kingfish51's Avatar
kingfish51
It probably needs adjusted at the latch and bumpstops. Ihad the vibration that showed up after installing a bug shield. After adjusting the latch and side bump stops, this went away.
I do believe there is a TSB for the adjustment. Might want to check with the dealer.
Old Sep 26, 2005 | 06:47 PM
Simmy150's Avatar
Simmy150
Ford may have had a TSB on this. I think the fix was a 4 mm tube that they had to insert in the hood edge closest to the windshield. Check it out with your dealer.
Old Sep 27, 2005 | 04:24 PM
wbarrett's Avatar
wbarrett
TSB Works
... I had that annoying hood shake and used the fuel line solution in the TSB to solve it. Didn't spend more than $5 or take longer than 15 minutes to complete.
Bill
Old Sep 27, 2005 | 04:27 PM
knutson's Avatar
knutson
thanks for the info guys.....
